Rebuild
 1-19  20-24
3175.20 In reply to 3175.19
Hi PaQ, to a certain extent I don't like to automatically switch things on or off like that if it leads to some loss of control.
I'm not really 100% sure that in all cases everyone wants to see the points, if you are focused more purely on the shape it is possible for the points to be a distraction especially just verifying visually that a tolerance based one is very closely adhering to the original.
Right now the way it is set up you have control of either way - if you have turned on control points it will show you the control points of the result, and if you don't have them on it won't, so there is some flexibility....
That's the reasoning behind it currently anyway.
3175.21 In reply to 3175.20
ok I see the valid points, and I'm probably too used to the 'old' rebuild script, having the show points behaviour.
3175.22 In reply to 3175.21
Note, that old RebuildCurve script doesn't show the curve control points in case of ThroughPts mode. It just highlights an "intersection" between the origin curve and new one (i.e. sample points).
Also it is possible to modify the Rebuild.js file using in-line script: moi.geometryDatabase.showPoints(); to meet your needs ;)
By the way, I have renamed that custom command to avoid a confusion - now it is called ReconstructCurve.
Petr
3175.23 In reply to 3175.22
Petr,
I use this tool alot and it seems to work for me????I can show points and see rebuilding points also either on curve through points curve or curve control points mode.
Can you elaborate more about what you posted?
3175.24 In reply to 3175.23
Petr,
Never mind, I think I see what you are saying. It doesnt show the "weighted points". It shows as if through points is used.
Show messages:  1-19  20-24
