Rebuild
 1-13  14-24
3175.14 In reply to 3175.13
In the rebuild command, I would like to see a "Make corner points" tick mark in both the # of points and tolerance options. This would give the most flexability. So both options can either "round off and fuse" or "corner point" entity segments.
3175.15 In reply to 3175.14
Hi Burr, "Make corner points" could be a good way to phrase it.
But I'm not very sure about putting it in for the tolerance-based one, it's kind of a bad combination with that option.
The tolerance based one is oriented towards building a result that has some level of accuracy to the original one.
So for example you can put in 0.01 in there and then the generated curve will be within that tolerance distance to the original. It's a simple way to reconstruct the curve without having to try and guess exactly how many points should be used to maintain accuracy.
If corners were ignored, that means that it would be kind of like ignoring accuracy and trying to get accuracy at the same time, probably making weird results in something basic like a rectangle. It would probably have to do something like add a bunch of points in only to the corner areas of the rectangle until it the corner got to a really tightly curved bend. That's not good...
If you want something rebuilt to a high accuracy level, but also have corners smoothed, you probably should do something more like fillet the sharp corners first so that you have produced a curved shape that can then be fit to accuracy throughout its intended shape, rather than getting some kind of arbitrary weird tight bends in the corner areas.
Maybe if you could post an example of where ignoring corners with a tolerance based rebuild would be useful it would help me to understand what you are trying to do.
I don't think I have even got a way set up to do that combination currently in the tolerance-based curve fitter, because like I said it's like asking for accuracy and not-accuracy at the same time - it is just not a match with what that fitter was designed to do.
3175.16 In reply to 3175.15
Hi Burr, so I tried hacking out the kink splitting from the tolerance based curve fitter, and the results are not at all good, just like I had thought.
So for example here would be the result of applying it to a rectangle:
Notice that having a corner in the middle of what is intended to be a smooth accurate fit throws a monkey wrench into things and causes undulations and wrinkles. As you tighten up the tolerance, those things get reduced in size but are still present near the corner spots.
Are you still sure you would want to have that?
I guess I could call it something like a "mess up your curve in weird ways" option... ;)
But that's kind of what I mean by it not being a good combination with an accuracy-based fitter.
3175.17 In reply to 3175.1
Hi Burr, so also maybe one thing that I didn't make clear before is that the each of the 2 modes use a really different mechanism to do their stuff.
The # of points mode is really simple, it just samples that number of points and does a "Curve through points" on those points.
The tolerance mode uses a curve fitting mechanism that recursively adds points to out of tolerance areas until it converges to the accuracy level that you have asked for.
They both build a new curve result from an existing curve, but process used is pretty different between them.
3175.18 In reply to 3175.17
>>>>I guess I could call it something like a "mess up your curve in weird ways" option>>>>
Actually, I can draw just like that without any extra commands, so I guiess it's not needed!
It makes sense, and the tolerance option being completly accurate is a proper result. Just having the old commands output in the # of points achieves my request anyway....
Although, maybe there is some food for future plugin thought!!!!!! Just draw a simple line or curve and apply the "mess me up by some kind of value" tool :o
3175.19 In reply to 3175.18
I suppose you allready think about it, but wouldn't be better is you automaticallly show points when you activate the curve rebuild command ? So you have a better feedback of what's apprend, and then turning show points off when the curve is rebuild.
Yes I know I'm a bit lazy, but for me this combo sounds good ... at first sight :)
3175.20 In reply to 3175.19
Hi PaQ, to a certain extent I don't like to automatically switch things on or off like that if it leads to some loss of control.
I'm not really 100% sure that in all cases everyone wants to see the points, if you are focused more purely on the shape it is possible for the points to be a distraction especially just verifying visually that a tolerance based one is very closely adhering to the original.
Right now the way it is set up you have control of either way - if you have turned on control points it will show you the control points of the result, and if you don't have them on it won't, so there is some flexibility....
That's the reasoning behind it currently anyway.
3175.21 In reply to 3175.20
ok I see the valid points, and I'm probably too used to the 'old' rebuild script, having the show points behaviour.
3175.22 In reply to 3175.21
Note, that old RebuildCurve script doesn't show the curve control points in case of ThroughPts mode. It just highlights an "intersection" between the origin curve and new one (i.e. sample points).
Also it is possible to modify the Rebuild.js file using in-line script: moi.geometryDatabase.showPoints(); to meet your needs ;)
By the way, I have renamed that custom command to avoid a confusion - now it is called ReconstructCurve.
Petr
3175.23 In reply to 3175.22
Petr,
I use this tool alot and it seems to work for me????I can show points and see rebuilding points also either on curve through points curve or curve control points mode.
Can you elaborate more about what you posted?
3175.24 In reply to 3175.23
Petr,
Never mind, I think I see what you are saying. It doesnt show the "weighted points". It shows as if through points is used.
Show messages:  1-13  14-24
