Groups postponed until v3
 1-13  14-33  34-53  54-60
3170.54 In reply to 3170.47
Hi Michael...
>Instead of separating the model into completely individual surfaces, you can instead select these 2 sets of
>faces (with a crossing right-to-left window selection after having selected just 1 face first):
Yes, this help a lot.... :)
3170.55
Okay, thanks Michael, I understand now - basically it'll create all your different shapes in on go.
I thought perhaps there was some other kind of generation where the rails were used together - I guess perhaps something like with the scaling rail included - just wasn't sure what you meant about sweeping multiple rails at the same time...
Welp I'm happy! I can go back and revisit a model when I first started using MoI and I tried to do a certain shape with the 1-rail sweep that didn't work.
Of course I could redo it with all the tricks and tips I've learned since then but then what fun is that! :-P
Thanks again Michael for a great update!
-Will
3170.56 In reply to 3170.55
Hi Will, yeah it's kind of like a "batch mode" for one-rail type sweeping.
It doesn't do any kind of new shaping, it's just more convenient for applying the same profile sweep along a whole bunch of paths without having to repeat the sweep command over and over again.
The connection to Pipe is that previously Pipe was the main thing available that would handle doing a batch process for making a lot of tubes.
Pipe still may be useful for some special things since it includes the option to make hollowed out tubes. But also Pipe only is set to make a circular cross-section and not just any cross-section curve like regular Sweep.
But unless you want to make a whole bunch of hollowed out tubes, you probably don't really need Pipe anymore.
Still working on the release notes, probably won't have them ready until tomorrow.
3170.58
Actually I was just about to reinstall Pipe2 exactly for the hollowed out functionality.
Thinking further, it would sorta be nice if that inner diameter (width in this case?) was carried forward to the new sweep capabilities.
The one thing I do in addition to piping is adding >ducts< which are usually some rectangular shape or similar. Having an inner diameter now for those would be nice.
I guess I could run the 1-rails with a smaller profile object and subtract from the larger one however...
-Will
3170.59 In reply to 3170.58
Hi Will,
That's exactly what the Pipe command does - it is basically a macro for making 2 sweeps and then booleaning the small center one from the large one.
I'm not sure exactly how a width or diameter would work for all cases with sweep, because sweep is not limited to only have a circle or rectangle cross-section, it can have any curve as the cross-section shape including non-planar ones...
In the future I would like to do something to make it possible to select a kind of group of curves for one cross-section, like this for example:
That would be more general purpose than having a single width or diameter parameter.
I have that on my list of stuff to look at for sweep in the future, but I'm not sure exactly when that will happen - definitely not for v2 though.
3170.60 In reply to 3170.59
That would be wonderful Michael!
Being able to create a profile like that would allow me to "core out" the inside of my sweeps with any kind of internal shaping - as always, the better way to do things... ;-)
-Will
Show messages:  1-13  14-33  34-53  54-60
