Object Snap with SHIFT Key
All  1  2-5
3167.2 In reply to 3167.1
Hi MrBraun, normally this is done in the reverse way for MoI - for normal use leave Object Snaps turned on all the time and if they are getting in your way you can temporarily disable snaps by holding down the Alt key.
It is also possible to set up a keyboard shortcut that will toggle object snap on or off on every keypress (when you type the key, not just hold it down). To do that go to Options > Shortcut keys and add in a new entry, for the command put in this:
script:moi.drawingAids.objectSnap = !moi.drawingAids.objectSnap;
3167.3 In reply to 3167.2
Tnx for the answer Michael! :)
Just one question: Moi 1.1 have problem with Win 7 x64? I have some problems into view!
I.E. if i make a loft surface the result are not good! Into 2.0 beta this not appears! :) When release this version? ;)
3167.4 In reply to 3167.3
Hi Mr. Braun,
Nothing that I know of specifically related to Win 7. The original version 1.0 does not work properly in Windows 7, but the updated version 1.1 will run there.
But certainly there are a lot of various fixes and improvements in 2.0, so you probably found a bug in 1.1 that is now fixed in 2.0 .
Can you please post an example model file so I can take a look?
Pretty soon, I will be putting out the last v2 beta in the next few days here, I'm just working on some of the last areas of it now.
3167.5 In reply to 3167.4
Soon i post one example! ;)
___________________________________
MrBraun - Moderator www.C4dHotline.it
Cinema4D R10 and MOI of course!
Show messages: All  1  2-5
