bricks?
All  1-4  5-7
3154.5 In reply to 3154.4
3D apps (like Carrara) are just a great combination with MoI.
Brian
Size: 41.5 KB, Downloaded: 71 times, Dimensions: 640x480px
3154.6
Thanks. I want the ability to place bricks for arches, also bricks offset outwards in a design, offset inwards, and other victorian brickwork features, so I think actual modeling is what I need. I have seen how tracing over a design reference in modo, for example, could allow me to do a push/pull method and everything else. But, I'm really liking the way MoI "looks", the crispness of the vector lines and shading. I know I will be using it in some way.
It's occurred to me just now how a program such as MoI could make brick walls. Make a grid of tubes in the pattern of the mortar then boolean that inset just partly from a slab and there you've got the grid of mortar and also the raised bricks.
EDITED: 7 Dec 2009 by SHOKAN
3154.7 In reply to 3154.6
If of interest and value.
The problem of modelling detailed design aspects--in any modelling app, including the brilliant Modo---is the huge sized files that can result.
Often making rendering times a nightmare.
Though I agree some basic modeling shaping of areas in MoI is very beneficial.
In Carrara, apart from using the images I have exampled before, we have the brilliant Shader plugin Veloute2 of which an example is attached.
I am sure you can attain similar results--as shaders--in Modo.
Keep the idea of the potential options in mind.
Brian
Size: 125.1 KB, Downloaded: 89 times, Dimensions: 1477x607px
Show messages: All  1-4  5-7
