Wire Frame Mode
3152.1
Just started to use Moi version 1.1 and I noticed there is no wireframe mode in the viewports just a solid view
Size: 132 KB, Downloaded: 57 times, Dimensions: 1152x864px
No true "Wireframe" mode but ;)
Menu Options / Display Hidden-line curves
Options / Display Hidden-line edges
If you are owner of the Moi 1.1 you can load the V 2 beta who has more options of display Color Lights etc...
http://moi3d.com/beta.htm
3152.3 In reply to 3152.1
Hi carmine -
Actually the default is a kind of combination mode, because hidden lines and curves are displayed in a faint dashed line style and you can still select them. So there is the same access to curves and edges as you would have in a full wireframe mode.
That's why there isn't really a big need to have a full wireframe mode in MoI.
If you want to get a "more wireframe-like" mode, then you can actually select face sub-objects and hide them if you want. That's much easier in v2 where the scene browser lets you hide all faces with just one click.
3152.4 In reply to 3152.1
Hi carmine, here's a quick demonstration image:
Notice there that it's actually not just a simple solid view, the edges that are hidden are displayed in a faint dashed line style, and you can also select them same as the front edges.
You can disable the hidden line display under Options > View if you want, but by default they are on and you should see them in your display.
They won't be very apparent in just a single sphere like you showed in your screenshot though since that has only one edge in it. If you make a model that is made up of more pieces and has more faces and edges in it then you will see them more easily.
