Not able to create a network
3151.1
I have made in my opinion a network, but Moi doesn´t make a network of this curves, moi makes nothing.
RUdl
Size: 176.6 KB, Downloaded: 91 times, Dimensions: 1440x900px
3151.2 In reply to 3151.1
Hi Rudl,
Split the basecurve(the one on the Cplane)in two pieces,
by using the trim command,and "push Done to keep all".
3151.3
Thank you,
one side looks good, but the other has some unbeautiful lines.
Size: 155.7 KB, Downloaded: 65 times, Dimensions: 1440x900px
3151.4 In reply to 3151.3
Hi Rudl,
Another try is to split the vertical curves and leave the basecurve intact.
Could you add the .3dm file,so Michael can take a look.
EDITED: 6 Dec 2009 by PAOLOLOBBIA
3151.5
Here is the .3dm file. I have the next question, ist it possible to give the form a thickness.
Rudl
3151.6 In reply to 3151.5
Hi Rudl,
Click "Offset" and "Shell"
Attached:the second try with vertical curves split and basecurve joined
3151.7
Hi Paolo,
thank you very much. Can you give me a short explanation, why my origin network didn´t function. Why must I split either the ground curve or both vertical curves.
I have another question. How can I make an opened shelled box; I don´t understand the explanation in the English PDF.
Thank you
Rudl
3151.8 In reply to 3151.7
Hi Rudl,
I think Michael can explain that better.
>> opened shelled box.
I guess you mean offsetsurf.
Offset works on curves,surfaces and polysurfaces(well in most cases!)
Example: draw a box(polysurf),select the topsurface and then delete it.
Click Offset and insert a distance less than the overall size of the shape.
3151.9 In reply to 3151.7
Hi Rudl,
Your original curve did not form a regular 2D pattern - Network has to unwrap the curves you give it into a 2D grid.
In your case, it looks like you have 2 curves that cross over each other and then come back to touch the same base curve.
Basically the curves you give Network need to be unfolded similar to how longitude and latitude lines on a globe are unfolded into a flat map. Now imagine if you had a single longitude line on the globe that touched the equator in more than one spot - that would not unwrap properly into a map... That's how your curves are set up.
Please see some of these previous threads for some more explanation and illustrations about this case:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1905.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=1778.6
http://moi3d.com/forum/index.php?webtag=MOI&msg=1484.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=2315.6
Make a regular box, then select just the face that you want to have open, then run Shell.
The faces that you have selected when you run the Shell command will become the opening.
To select a face, you click a second time on a solid - the first click on a solid selects the whole object, and then a second click will "drill in" to select either edge or face sub-objects. In this case you want to select a face sub-object before running Shell.
