Hi Mark, also is there a particular reason why you are looking for the angle?
Is it to do something like rotate some object back to be horizontal or anything like that?
Because for those kinds of things, you don't actually need to know the specific numeric angle you can instead pick the reference points in the Transform/Rotate command on to the appropriate spots and it will figure the angle to rotate between the points for you.
