Recommended free renderer - An old question, maybe a new answer?
 1-19  20-39  40-59  60-69
3136.60
Don't if it was said but i usually look at all the 3D mag each month to see what kind of free software they have.
I got a free copy of Carrara 7 pro from a 3D mag, full commercial value.
I got Truespace that it is free i think.
Denis
| CorelDraw Grahics Suite X5 | Daz Carrara Pro 8 | Moi 3D V2 |
3136.61
So Rendergin is advertised (is that correct ?) as a realtime nurbs render engine ... that finally cant open nurbs data (at least with the trial version) and give slow renderspeed Oo.
... wonderfull world :)
Btw the comparaison seems a little bit biased ... the poly version on the right looks more like a vertex normal glitch than anything else. I never had to push the polycount that high when exporting MoI model into Modo.
Thea render seems indeed really nice product.
EDITED: 3 Dec 2015 by PAQ
A new one is coming for Blender internal render engine! Cycles! (real time gpu )
http://www.youtube.com/watch?v=tSIx_o0IOXk
http://graphicall.org/ you must load a build in these pages following your config ! (Scroll pages)
(all are a version of Blender + versions of test of some different plugs ;)
Before integration in a stable end version !
3136.63
until now there is no GPU Window version.
I will wait until they have one.
Rudl
3136.64 In reply to 3136.63
yes you must have Linux version :)
But as I see that today a no cuda version WIndows is arrived, maybe the Cuda version if for a few time ;)
PS About about RenderGin : works a little more better today with the same file! :)
But has always numerous "splats crash" for many manipulations!
Something annoyous : don't respect color given in MOI (no color)
3136.66 In reply to 3136.63
<< until now there is no GPU Window version.>>
That isn't true. There have been a few Win GPU versions (albeit a little dated).
Here is one for Win64:
http://graphicall.org/198
Here is one for Win32:
http://graphicall.org/130
3136.67
Seems I have missed the development.
Rudl
3136.68 In reply to 3136.61
PaQ and Pilou,
I've made some further tests, it seems NURBS import works fine when exporting from NX 7.5 and using Rendergins "OpenCASCADE" nurbs importer. Below you can see an example, where the solid on the left is perfectly represented, despite very complex loft and blend surfaces being present:
In addition I received this message from the Oliver Abert, regarding some import issues I was having:
"it would help if you could send me a screenshoot. However, from what you describe I am pretty sure it's a known problem occuring from to conservative NURBS parameters (for our internal stuff). You could try to increase the settings for the NURBS (in the NURBS plugin settings). However, beta 3 is quite old (from October 2010) and in the meantime we have worked a lot on all parts of the software, but especially on the NURBS. Unfortunately at this point in time I cannot say when we will release a new version. We decided to go back, work under the radar and then finally release a really polished version once it is done. Keep an eye on our homepage and/or Facebook account for major announcements hopefully in the near future!"
3136.69
Show messages:  1-19  20-39  40-59  60-69
