WIP Car Wheel
3118.1
Hi all
Coming a little bit by bit back to 3D.
Love the new options in MOI, pretty cool stuff added for the V2. Can't wait for the final release.
Started a Car wheel and i am designing as i go with no reference except the stuff in my head and what i learn over the years. Hope i can do something decent. :)
Cold
| Adobe Photoshop CS | Corel CorelDraw Grahics Suite X3 | Daz 3D Bryce 5.5, Carrara 6 Pro, Hexagon 2.5 | Maxon Cinema 4D R8.2 | Moi 3D |
Gallery
EDITED: 8 Dec 2009 by DENISJAGUAR
3118.2 In reply to 3118.1
Welcome back to the world of 3d modeling! :)
Looks like you are off to a great start, look forward to seeing your updates.
3118.3
Yes Moi is great. I love it to model with no reference. In this case with no correct norm values (wheel nut ). The hardest part was to find a way to bend the center of this wheel. I've project the curve on a sphere and cut the lines. I didn't find an other way. My first try to select the point and move them down was not bad but I couldn't extrude the curve with caps. My test below.
Regards from Bavarian
Size: 99.4 KB, Downloaded: 120 times, Dimensions: 800x600px
3118.4 In reply to 3118.3
Hi Apophis,
Possible for the center hub, some kind of revolve of a profile curve.
3118.5
Hi BurrMan
Revolve- I will do some tests.
Thanx
edit: has you any idea for this kind of curve. my alternative again with proj.
EDITED: 21 Nov 2009 by APOPHIS
3118.6 In reply to 3118.5
Hi Apophis,
In the one i am working on i started from a cylinder and using some boolean operation then fillet on the line selection.
Revolve will do the trick for the curvature. The bar in the wheel was made with sweep 2 rails.
This is another test i did with a plain sphere and cylinder with the boolean and fillet operation
Have you ever seen this one in Rhino http://www.toxiclab.org/tutorial.asp?ID=124
I found that Rhino3d has good tutorial for making a car. I registered on there web site (it is free) and you can download the tutorial parts. the one about the rim should help you out. http://www.rhino3d.tv/english/info/accessdenied.php
or Here http://www.carbodydesign.com/
3118.7
my last test this weekend. i'm not funny with revolve. project on a surface was my favorite way - until now :-)
if i've time next week i will try further tests. ähm sorry for entering this treahd. it's not gentlemen like.
regards
Size: 90.4 KB, Downloaded: 94 times, Dimensions: 800x600px
3118.8 In reply to 3118.7
Don't need to be sorry Apophis, better 1 thread of the same subject then multiple with the same subject, easier to follow.
And yes you are a gentleman, you are showing your work. :)
that is much better, did you fillet the lien around the hole for the bolt?
Cold
Gallery
3118.9
yes the lines around the hole for the bolts was rounded.
i've found a mistake. the outlines from the centerwheel should be rounded.
this could be a really tricky place to clean ist. :-)
Size: 149.6 KB, Downloaded: 71 times, Dimensions: 800x600px
3118.10 In reply to 3118.9
Yeah you had to pointed out even for me to see it, didn't the first time. Still this is a better wheel there.
Cold
Gallery
3118.11
A new update, started from scratch. (yep that is me changing my mind to often, crazy stuff in there too :P)
Cold
Gallery
3118.12
Update
Cold
Gallery
