Looped edge selection
 1-16  17-36  37-56  57-63
3112.57
just to clarify I did mention that I use Cintiq 21UX on my first post, the SpaceClaim MultiTouch link was more of a show case on finger gestures in a CAD application...
also last thing I want is to play/sketch on a iphone on the other hand using SketchBook & MoI on tablet it does make sense to me.
perhaps there is a language barrier here :(
3112.58 In reply to 3112.57
Hi neo,
It does look pretty cool! I wish that I had more time available to me so that I could play around with it and experiment with some similar stuff.
But sadly my time is limited and there is currently more mainstream type stuff that needs attention first.
I am confused now - why did you specifically mention the iphone/ipod touch as an example then?
At any rate, like I mentioned it is important to me to not mess up the stuff in MoI that does work well on a tablet currently.
I understand that you wish that I could work 100% of the time only on refining MoI for multi-touch. But that's just not what the larger number of my user base needs for me to be focused on.
EDITED: 22 Nov 2009 by MICHAEL GIBSON
3112.59
I've set up a shortcut key for this inline script / MoI edge loop select function:
script: /*Edge loop selection*/ moi.geometryDatabase.selectLoop();
But a lot of the time when I select two edges and run the script, the result is not as I'd expect. Here's an illustration:
The first image shows two edges I selected, the second image shows the result, and the third image shows the selection I'd love to see.
Is there maybe a possible workaround or different approach to get the desired edge loop selection?
Many thanks.
Regards,
— Metin
visualization • illustration • animation • 3D design — metinseven.nl
3112.60 In reply to 3112.59
Hi Metin,
Sorry no, not currently. Right now the loop selection mechanism works as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.22
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.32
It tries to target a trimming loop on one face. The result you are looking for is crossing over 3 different faces it looks like.
3112.61 In reply to 3112.60
Thanks Michael,
It'd be great if you could maybe add recognition of edge continuity across faces to the V4 features, for easier edge loop selections. I use those edge loop selections a lot for fillets.
Regards,
— Metin
3112.62 In reply to 3112.61
+1 to this request please!
Something like this, so the red lined loop would be selected, not the current yellow selection.
t
3112.63 In reply to 3112.62
Hi Tover, can you please post your .3dm model file or e-mail it to me at moi@moi3d.com so I can take a look?
Show messages:  1-16  17-36  37-56  57-63
