Face extrusions
All  1  2-4
3091.2 In reply to 3091.1
Yes Burr, I can confirm this problem also, it only happens when extruding the surfaces of the cube facing the x,y,z negative direction trying to extrude in the same direction, the only way I could correct it was to select the set direction option in extrude.
3091.3 In reply to 3091.1
Thanks for reporting this bug, Burr.
It looks like this bug got introduced into the last beta when I changed face extrusion in order to solve a different bug, the one that was reported here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2999.1
That was meant to make a set of individual faces that are all on the same plane extrude in a common direction rather than each one going on its individual normal. But one piece of the change is kicking in for this case you show here when it isn't supposed to so I will fix that up.
3091.4 In reply to 3091.3
Ok, good luck. And just to make myself feel good, I knew it was from that font thing :O
Thanks Danny for looking.
Show messages: All  1  2-4
