offset curve on surface
3072.1
can I offset a curve on a surface?
I have created an intersection between a plan and a freeform surface.
I would like to offset this line so that it is 50cm apart, on the surface, in order to create a series of lamelles which are evenly spaced.
Is this possible in Moi?
3072.2 In reply to 3072.1
Hi okapi, MoI does not have any special function to offset a curve on a surface.
But depending on what you want, it may be possible to create a tube around your curve using Sweep, and then intersect that tube with the surface using Construct / Curve / Isect to form a curve at the intersection.
Does that do what you need?
Or something like that with "double" Array Lines, Project, Shell ?
3072.4 In reply to 3072.3
thanks for the info. It would be good to have such a function at some point.
I am using something similar at the moment. Except that I have used the array on spline function to space the cutting lines along the surface.
However this breaks down in places where the surface changes abruptly.
3072.5 In reply to 3072.4
Can you then take all the arrayed lines and raise them up a bit and project them onto the surface in place?
3072.6 In reply to 3072.5
Hi Burrman,
well I use the Curve -intersection tool which gives me a good result, but the surface is curved in 2 directions,
which means that where the curve becomes extreme, the lines are not 100% parallel.
I will have to upload an example.
I got something good enough right now, would be good to have an automatic tool for this at some point
3072.7 In reply to 3072.6
Hi okapi, I would like to have that in the future, but unfortunately an offset curve on surface function is not easy to create and it is not currently available in the geometry library that I use for MoI.
So it will probably be some time before it would be possible to add it as an automatic tool.
Check out this previous thread for some discussion on it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3021.8
