Converting points on a tablet pc
All  1-3  4-6
307.4 In reply to 307.3
> after you finished with drawing tool then say you select the
> curve/line and show points and then how do you convert a courner point
To do this, you use Edit/Add pt, and check the "Make corner point" box, then add the new corner point nearby the point you wish to convert.
Then select the old point and delete it - you will be left with just the new corner point.
Eventually there might be some other method to convert an existing point, but for the time being just inserting a new one should get you the result that you want.
307.5 In reply to 307.4
Simple and Tricky:)
307.6
Ok that will do
thanks for the quick responces
I'm no expert by far but I must say this app is soo much fun to use
Show messages: All  1-3  4-6
