Converting points on a tablet pc
307.1
Hi been using Moi just to learn more Graphics and play about on a tablet pc
the pc is 2 years old and has a modest spec 10.4" display 1ghz processor and I must say
Moi runs very very nicely - Makes me want to get a gfx tablet for my desktop machine!!
also using Moi as Amapi is hard to use on my tablet pc in tablet mode and other software dont run very well at all
Hexagon for example is problamtic as needs OpenGL1.4
Anyway great program Moi! - look like i'll get this once you make it available
Question though is how do you convert a point from a corner point to a curve point without using a keyboard?
is there away to do that?
307.2 In reply to 307.1
Yes you can :)
When you draw your curve you have a Menu Up Right Corner Page Screen :)
Just Enable / Disable "Make Corner Point" as many time you want
et voila
Have happy Modeling without keyboard ! :)
That's magic all with only the pen or the mouse!!!
307.3 In reply to 307.2
ok thanks but is there a way to do that after you have made a curve/line?
after you finished with drawing tool then say you select the curve/line and show points and then
how do you convert a courner point
307.4 In reply to 307.3
> curve/line and show points and then how do you convert a courner point
To do this, you use Edit/Add pt, and check the "Make corner point" box, then add the new corner point nearby the point you wish to convert.
Then select the old point and delete it - you will be left with just the new corner point.
Eventually there might be some other method to convert an existing point, but for the time being just inserting a new one should get you the result that you want.
307.5 In reply to 307.4
Simple and Tricky:)
307.6
Ok that will do
thanks for the quick responces
I'm no expert by far but I must say this app is soo much fun to use
