Capping extrusions, wireframe visibility
All  1  2-4
3048.2 In reply to 3048.1
Hi Mark,
> is there a way to get it to cap just one end instead just both or neither,
Nope, there's just a simple checkbox for the "Cap ends" option, so it's either both or neither for that one.
> Once it's extruded without caps is there a way to then cap one end,
Yep, you can select the edges along the end you want to cap, and then run Construct / Planar to build a planar surface through them, then use Edit / Join to join the new plane cap with the main body.
> Once it's extruded with caps is there a way to remove one
> of the caps?
Yep, this is probably easiest - you just select the face you want to remove (by drilling down, that is when you click a second time on a solid) and hit Delete to remove it.
> I there a way to change the display from ghosting to
> wireframe and back on the fly? When ghosting, is there
> a way to make the hidden lines show up better, be more visible?
What do you mean by "Ghost" - do you mean hiding or locking objects?
There is an option in moi.ini for adjusting the opacity of hidden lines, that is under:
[Hidden lines]
HiddenLineOpacity=34
You can edit that to a value between 0 and 255, with 0 being totally transparent, and 255 being totally opaque.
But that will change it for everything, not just in one circumstance.
3048.3 In reply to 3048.2
Is there a way to display 3D objects as wireframes?
3048.4 In reply to 3048.3
Hi Mark,
You can hide all the faces and leave only the edges showing.
In v2 there is a quick way to do that using the Scene browser - go to the Types section and there is an entry there for "Faces" - click on the eye there to hide all faces and you will be left with only a wireframe view of your model.
Show messages: All  1  2-4
