Incorporating an stl model in Moi
All  1-2  3-13
3044.3 In reply to 3044.1
>I would like to create a model in Moi, import one of those stl model then save it as an stl file.
hi ggagnon,
import STL in Wings3D, save it as OBJ
import OBJ in MoI with Obj23dm plugin
export OBJ from Moi to Wings3D then export to STL
Wings3D* is free, last v. is 1.2rc1 to download at www.wings3D.com
* (IMO the best free polygon modeler of galaxy)
3044.4
Thanks you Michael and ycarry.
I have tried MiniMagics. Nice viewer, loads the stl file very fast, can import and show many files at once but no way to reposition them with respect one from the another. Worst in my case, the objects cannot be combined at save time.
ycarry, I have tried your suggestion and convert the stl --> obj --> 3dm. The resulting 3dm files contains 129692 Curves :o understandably Moi3d slows down to practically a halt. Thanks you for introducing Wings3D though.
What sotfware would you use if you wanted to make models like the ones shown here? Could this me made in Moi3d?
http://www.vectorart3d.com/store/
Thanks again,
Gaston
3044.5 In reply to 3044.4
A program called Zssurf will make a relief from a bitmap in the 3dm format. I use it.
http://mwt.net/~sjedging/ZSURF4.zip
3044.6 In reply to 3044.4
Hi Gaston - yeah the OBJ to 3DM converter only extracts the wireframe of the polygons to bring into MoI as curves.
That can be useful if you want to use them as a kind of snapping framework or reference while modeling a new version of it, but that will not work well for exporting to STL since STL needs to have surface data and not curve data.
For example if you just draw several lines, that cannot export to STL either, that's the same kind of thing that you have (wireframe only, not solids or surfaces) when you use that particular converter.
It's not really a good fit to do those kinds of bubbly relief type patterns in MoI.
Bitmap-based tools are a good fit for that, like Burr mentions ZSurf is a free tool and there are also ones like ArtCAM which are specialized for that kind of modeling only.
See some of these previous threads for some more information:
http://moi3d.com/forum/index.php?webtag=MOI&msg=602.7
http://moi3d.com/forum/index.php?webtag=MOI&msg=2799.8
http://moi3d.com/forum/index.php?webtag=MOI&msg=2640.1
Also aside from these "2.5D" programs which take a bitmap and then make a relief out of it, there are also some brush-based sculpting programs which can be good for doing relief type work. For those see these 3 programs: 3D-Coat, ZBrush, or Mudbox.
3044.7 In reply to 3044.6
Thank you Michael for the enlightenment :)
I definitely have to learn more about those file format. Although it should not be hard to find, if you know a specific tutorial on the subject, I would appreciate.
Gaston
3044.8 In reply to 3044.4
Hi Gaston,
"What sotfware would you use if you wanted to make models like the ones shown here? Could this me made in Moi3d?"
Many of those particular pieces at Vector Art 3D were made using Silo.
Here's a link to the Silo Forum with info about how they were created.
http://www.silo3d.com/forum/showthread.php?t=8869
Another option for making those 2.5D type of images would be the Aspire program.
http://www.vectorart3d.com/index.cfm/Aspire_Software.htm
Hope this helps, Colin
3044.9 In reply to 3044.7
Hi Gaston,
Are you talking about the brush-based sculpting type programs?
I don't really know of any tutorials specifically myself, but there are probably several on each of the web sites for those programs.
3D-Coat: http://www.3d-coat.com/
ZBrush: http://www.pixologic.com/home.php
Mudbox: http://usa.autodesk.com/adsk/servlet/pc/index?id=13565063&siteID=123112
3D-Coat is probably a good one to focus on.
3044.10 In reply to 3044.8
Thank you Colin,
Now I know where the "Happy Dog" I purchased at $25 comes from :)
Aspire at $2000 is way out of hobbyist range, at least my range ;)
Gaston
3044.11 In reply to 3044.9
No, I was referring to the basic of graphics I suppose: the jargon used like meshes, nurbs, polygons, ... rendering ... the plus and the limitation, divers file format used etc.
A simple tutorial on the basics.
Thanks you anyway, you have given me enough to "thinkering" with for the next little while :)
Gaston
3044.12 In reply to 3044.11
Hi Gaston,
The problem is that there is not just one activity that computer graphics are used for, there are a whole bunch spanning from things like "Piping design for industrial waste management" all the way to "movie special effects" ...
The details of exactly what technology, file formats, etc... is used are different between those various uses of computer graphics.
So it's difficult to have an "overall tutorial" on such a wide ranging field, you need to look for things that are focused more on a particular kind of activity that you are interested in.
Maybe something like this could be useful as a general overview though:
http://www.amazon.com/Computer-Graphics-Dictionary-Advances-Development/dp/1584500190/
3044.13 In reply to 3044.12
Done. Thanks again.
Gaston
Show messages: All  1-2  3-13
