number pad
All  1-7  8-9
3039.8 In reply to 3039.7
Hi eric, I think your best bet for the moment will be to leave the units in MoI as inches (not feet & inches) so that it will be the same as what you have in Rhino.
You will still be able to type in ' " type notation using the keyboard, but there won't be the buttons in the pop-up panel.
I will do some work for the next v2 beta to enable having the pop-up have ' and " buttons available when you have units set to inches.
If you want to type in coordinates into something other than the first field, like in Rectangle where there is a Width: and Height: both showing, push Tab until you get to the field you want and then you can type in your value.
3039.9 In reply to 3039.8
Thanks Michael ...
That's what I have been doing ... it works, certainly, but I do look forward to the next beta.
cheers,
eric
Show messages: All  1-7  8-9
