A feature in history system, please - tracking of a snap.
All  1-6  7-8
3036.7 In reply to 3036.4
Hi Allan,
> One more suggestion in the history theme: Is it possible to
> do track also weight of this curve?
Unfortunately that's not easy to do, since the Conic command does not take any weight parameter as part of its input, it only takes 3 points.
So that means the only history that is recorded for it is 3 point x,y,z locations and not any other factors.
> Maybe also a weight of blend.
Yeah the "Bulge" factor for blend is tracked currently - it is reapplied when you move the input curves into blend around.
This one I do have some hope of making the bulge factor editable in an enhanced history edit function in the future.
3036.8 In reply to 3036.6
Hi Allan,
> Maybe a first solution to the problem is to add functionality
> where selecting a blend curve and toggling on history in a panel.
Yup, that's definitely something that I want to add in the future which would be a major enhancement for History.
The only problem is that it will take quite a lot of work to make that happen.
I do hope to make some progress on it in v3 though!
Show messages: All  1-6  7-8
