| Hi Allan,
 > One more suggestion in the history theme: Is it possible to
 > do track also weight of this curve?
 Unfortunately that's not easy to do, since the Conic command does not take any weight parameter as part of its input, it only takes 3 points.
 So that means the only history that is recorded for it is 3 point x,y,z locations and not any other factors.
 > Maybe also a weight of blend.
 Yeah the "Bulge" factor for blend is tracked currently - it is reapplied when you move the input curves into blend around.
 This one I do have some hope of making the bulge factor editable in an enhanced history edit function in the future.
