Indie / Unity is free!
All  1-6  7-9
3035.7 In reply to 3035.1
Can be trees and plants exported as mesh objects (obj, 3ds, ?) from the free version?
Visualisation for Designer and Architects | http://www.simulacrum.de
3035.8 In reply to 3035.7
I suppose yes :)
http://www.unifycommunity.com/wiki/index.php?title=ObjExporter
Based on ObjExporter.cs, this "wrapper" lets you export to .OBJ directly from the editor menu.
This should be put in your "Editor"-folder. Use by selecting the objects you want to export, and select
the appropriate menu item from "Custom->Export". Exported models are put in a folder called
"ExportedObj" in the root of your Unity-project. Textures should also be copied and placed in the
same folder. */
3035.9 In reply to 3035.8
Sounds good. For 3D-PDF use a light vegetation can be very useful.
Micha
Show messages: All  1-6  7-9
