Indie / Unity is free!
All  1-5  6-9
3035.6 In reply to 3035.5
Unreal is also free. It is more powerful than Unity but PC only.
3035.7 In reply to 3035.1
Can be trees and plants exported as mesh objects (obj, 3ds, ?) from the free version?
Visualisation for Designer and Architects | http://www.simulacrum.de
3035.8 In reply to 3035.7
I suppose yes :)
http://www.unifycommunity.com/wiki/index.php?title=ObjExporter
Based on ObjExporter.cs, this "wrapper" lets you export to .OBJ directly from the editor menu.
This should be put in your "Editor"-folder. Use by selecting the objects you want to export, and select
the appropriate menu item from "Custom->Export". Exported models are put in a folder called
"ExportedObj" in the root of your Unity-project. Textures should also be copied and placed in the
same folder. */
3035.9 In reply to 3035.8
Sounds good. For 3D-PDF use a light vegetation can be very useful.
Micha
Show messages: All  1-5  6-9
