Thick line
3033.1
I've inserted a script form the forum,by mistake and stupidity I've forgot wich one is it.Something with caps loc,that makes all the lines very thick.But looks horrible,I've deleted the script but still the problem occurs.What should I do?How do you undo a script?(not ctrl+z,it's not the same thing).
Please let me know,I am in a big troble(didn't want to use bad language guys :P )
Thank you,
Alex Cruceru
EDITED: 28 Oct 2009 by ALEX_CRUCERU
Size: 100.9 KB, Downloaded: 90 times, Dimensions: 1173x842px
3033.2 In reply to 3033.1
Alex, if you have deleted the script, please restart your computer. ;-)
3033.3 In reply to 3033.2
It does not work.I have some PC problems I think,but this script problem is silly,still going.Help me! lol.It's horrible to my eyes,I do not get it.:(((
3033.4 In reply to 3033.1
Hi Alex,
this should help, just define script below as a command part of shortcut and run this newly defined shortcut
script:moi.view.lineWidth = 1;
Petr
3033.5 In reply to 3033.4
THANK YOU! ALELUIA! :) lol,thanks again my friend.This is perfect.I can finally work again,have a great day.
Alex Cruceru
3033.6 In reply to 3033.4
One for Petr's MoI page?
3033.7 In reply to 3033.1
Hi Alex, so what happened there is the script set the line width property for the display and that property gets saved in the moi.ini file.
If you have something like that happen again where something is still changed after you restart MoI, that definitely means it has been saved in moi.ini .
In MoI v2 there is an option to make it easier to edit the moi.ini file directly, that's under Options > General > Edit .ini file button.
