something not good
All  1-4  5-15
3011.5
hi there..
did you use the TRIM command in your first example?
you could use Petrs RebuildCurve-command to clean up that curve..trims fine afterwards
cheers,
marco
EDITED: 23 Oct 2009 by MARCO
Size: 39.6 KB, Downloaded: 47 times, Dimensions: 800x600px
3011.6 In reply to 3011.5
Yes I used TRIM in the first case but at the last one this method dont work as well. unfortunately
3011.7 In reply to 3011.6
Andras,
With the first model, You would use the "Merge" command to have your curve "not seperate" in that area.
Select surface and run trim and select curve. Remove inner surface. Select both edges of new trimmed surface and type Merge<enter>. Ths will combine those 2 edges back.
Michael will probably explain what is going on there.
3011.8 In reply to 3011.7
In your second model, you want to look at this area:
Zoom in there to see this:
That area there where you have the 2 edges so close together and intersecting with the other objects seam edge is going to be problematic for many operations down the road. You may want to revisit the method you created that surface with and realize how that little area was created, then avoid doing that in the future. Most likly when you did the extrude or whatever op you used top create that surface you had 2 seam points just grazing by each other.
But you can get what you want with your first initial method and Merge.
3011.9 In reply to 3011.1
Hi andras, yes you get edges in separate pieces in that case because your cutting curve is not just one single piece, it is actually a curve made up of 2 segments.
If you select that cutting curve and run Edit/Separate on it, you can then select the segments individually to see that.
So for example after running Edit/Separate you can see this:
I think that Burr has got a good solution for you above - use the new Merge command in v2 (which you need to either type in or set up on a keyboard shortcut to run it). You can either select the whole object, or just those 2 edges (hide the original cutting curve to get it out of the way) and then when you run Merge it will fuse those 2 edges together into one single longer edge.
Please let me know if that still does not solve your problem.
3011.10 In reply to 3011.9
It is fine until the Blend command when I want to weld the two edge.
the picture represent my probleme:
in the case1 the probleme is visible
in the case 2 relative fine result.
the different is just the two kind of curve. In the case2 I changed a litle bit the two "edges" for Blend command.
maybe is it an simmilar then previuos Loft-case? the curves directions are changed and the result is ... hmmm... I will check.
3011.11 In reply to 3011.10
Hi andras, a couple of different things happening for your #1
First thing - for blending it is a good idea to blend between 2 open edges.
But your blend target does not have an open edge, it is a solid. I'm talking about this piece here:
There are 2 faces that are connected to an edge in a solid like that, and it will be kind of random which face will be picked to be the blend target in a case like that.
To make it not random, it is a good idea to select the top face of your solid there and delete it, that will help to clarify that the vertical face is the blend target, because that will then be the only face that is attached to that edge.
Some more info in a minute...
3011.12 In reply to 3011.10
Hi andras, some more information on your #1.
So when you do a blend between 2 closed edges like this for example:
Part of the controls that will come up is a "seam alignment point" that will let you adjust how the 2 closed curves are being connected together, it will show up as 2 small points like this:
If you do a the blend on your #1 case, you will notice that you do not have those points available. That's because the top edge there has a little tiny gap in it:
That's a big enough gap that the blending code does not consider that top edge to be closed.
The blending mechanism will only be able to put up an adjustable "seam point" for blending between 2 closed edges, when edges are not closed they can only be flipped to help with orientation, not "re-seamed".
How was the top edge curve created for your #1 case, was it from trimming your previous shape that you posted followed by Merge or was it from some other steps?
Whatever produced that top edge may need to be tuned up to "true up" the endpoints when there is a topologically closed loop being formed but the endpoints are slightly apart from one another.
3011.13 In reply to 3011.10
Hi andras, also another problem that you will kind of run into is that trying to make a blend that covers a rather large distance and between shapes that have a tighter bend in them will tend to make bunching.
That's because blending tries to keep its surface to be perpendicular to the edges.
When something is forced to be perpendicular, and also travel a fair distance, and also go through a tight enough curve all at the same time, it tends to create a kind of "bunching" like this:
That will probably create some surface artifacts like weird little wiggles in your result when there is not quite enough space for the blend to easily fit.
3011.14 In reply to 3011.13
yes I know this effect I have already met with this several times I keep in my mind.
The MERGE command finally worked well thank you. Just I dont understand is this an separate command? because firstly I tried between the Boolean Merge and finally with the Shortcut method... that was fine.
3011.15 In reply to 3011.14
Hi andras,
Well, even though it has a similar name it does a different kind of thing than the BooleanMerge command.
BooleanMerge will intersect surfaces with one another and extract all volumes that are produced.
The other Merge command is about merging 2 edges that touch one another into a single edge.
They do different things so they are different commands.
Show messages: All  1-4  5-15
