Rhino line types
 1-12  13-21
3004.13 In reply to 3004.11
Hi Michael ..
Yes, as long as I set up Rhino with the same layer names as MoI styles and set the linetypes I want in Rhino then 'import' works great and all the display and print functions perform the way I expect them to. I use Rhino 5 beta now and it works one way like a charm.
The other aspects of styles that you set up are great ... I am enjoying learning the routines.
I am soon going to start my first set of architectural working drawings in MoI ... while you have not set up MoI for this purpose yet I think I can get the translation back to Rhino for dimensions and notes. It will be an interesting challenge.
thanks again for your good work and your superb support.
cheers,
eric
3004.14 In reply to 3004.13
Hi again, Michael ...
I have been doing a little more playing with the MoI / Rhino interchange attempting to move 'styles' back and forth ... particularly linetypes.
Using Rhino 5:
If I carefully set up a template in Rhino with everything I think I will eventually need ... linetypes, layer colors, lineweights, etc ... and then open the template in MoI I can
Prepare a two or three dimensional drawing using those preset styles and then 'export' this drawing to a file (don't 'save' it ever) ..
Then I can open the original template in Rhino 5 and 'import' the drawing prepared in MoI ... all my linetypes, colors, and lineweights are there ... alive and well ... ready for dimensions and notes and the assignment of render materials.
I have had all the advantages of the easy modeling MoI is capable of and the other stuff I need from Rhino, too.
One other small caution ... 'insert' brings the MoI drawing in, too ... and it looks o.k. for color and linetypes and stuff but it is all on the same layer it was inserted into ... a real mess.
Also do not open the MoI 'export' directly with Rhino 5 ... it does not automatically bring the information with it.
As I said in the last post I hope to use MoI for a set of architectural working drawings soon ... implementing with dimensions and notes with Rhino.
I'll let you know if the workflow functions for me.
cheers,
eric
3004.15 In reply to 3004.14
Hi Eric,
Not sure if you saw this, but I've previously posted a MoI-Rhino4 Template file that I made.
I'm assuming that it'd work the same in the new R5 WIP as it does in the current R4?
Hopefully it's of some use to you.
regards Colin
3004.16 In reply to 3004.15
Hi Colin ...
Thanks ...
I opened the file but it seems to contain only the default Rhino layers ... default and layers 1 through 5
eric
3004.17 In reply to 3004.16
Hi Eric,
Sorry, I was under the impression that's what you were after...a MoI template that had the Rhino Default Layers already setup.
Just thought this might save you some time.
regards Colin
3004.18 In reply to 3004.17
Again, thanks Colin ...
What I needed and have set up is a template for my architectural drawing needs ... many layers from foundations to framing with lots of linetypes and differing colors.
So far it is working well as long as I remember not to 'save' my MoI created drawing ... but to export it instead. THen I can import it into my Rhino job template without losing all that custom stuff.
cheers,
eric
3004.19 In reply to 3004.18
Hi Eric,
Maybe customize the MoI UI and remove the Save buttons :O
3004.20 In reply to 3004.18
Hi Eric, a couple of notes -
If you Right-click on the Open button instead of left click it, that will do an "Open Template" rather than a regular open.
The difference is that "Open Template" does not set the current file name in MoI so it is not so easy to accidentally overwrite the file that you open.
There's also another option related to this which you can set in moi.ini (use Options / General / Edit .ini file button).
[FileDialog]
EnableReadOnlyCheckbox=n
If you switch that to =y, then for the regular Open there will be an "Open as read-only" checkbox at the bottom of it which you can check to turn on. When that option is checked on the file dialog, it will also prevent Save from automatically writing to the current file name and instead prompt you for a name like "Save As".
So either of those methods can help to prevent Save from overwriting the current file if you want to guard against that.
Also I think that Copy from MoI and Paste into Rhino should end up working as the equivalent of Export / Import, so that is possibly another way to move your objects back without disturbing the line types and also not overwriting any files.
3004.21 In reply to 3004.20
Thanks Michael ...
I'll try those.
It does seem that any MoI save of the drawing destroys all the linetype settings so it is not safe to do any interim saving of a drawings ... though if I export the whole thing all the layers I have used in MoI will come back into Rhino if I import the drawing into a preset template (in Rhino) then all the MoI work carries all the information.
I do hope that one or more of these suggestions smooths the process a little and I do look forward to the day when there is a facile turn around.
Except for dimensions and notes MoI is already a very good 2d drafting tool and all the work converts so easily into 3d when needed.
thanks again,
eric
Show messages:  1-12  13-21
