Hide only seams generator
All  1-6  7-11
3003.7 In reply to 3003.6
> I can't have this in the mesh export viewport
Well no, because that does not show you the polygon structure of the data.
The main purpose of the mesh export is to show you the mesh data, not to try and show you the NURBS edges...
When you do mesh export, the thing that you are seeing on the screen is not your NURBS object anymore, it is a polygon object.
3003.8 In reply to 3003.1
Hi Pilou
>>Does it possible to hide only seams generator automatically? (Select?, script? )
>>Because if you hide edges, "edges of intersection" after boolean union are hidden too!
>>Or a special box on the browser?
Yes for seams from BaseObjects only.
Shortcut: H or ...........
script:var gd = moi.geometryDatabase; var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getSeamEdges().setProperty( 'hidden', true );
Bevor
After
see, not everything goes in hidden status (Front right)
-EDDI
3003.9 In reply to 3003.8
eddi wrote "See, not everything gets hidden"
that's because it's not a seam edge anymore. Looks like it was a seam edge but you trim away (via boolean) so the remaining part was two distinct pieces of the original sphere. So I think the display is correct...
jonah
3003.10 In reply to 3003.8
Hi Eddi, yeah I think Jonah has it described well above.
If you use Edit/Separate on that object, you should see that there are 2 pieces there that you can drag away independent from one another.
A seam edge is when there is the same 1 surface on both sides of the edge.
It is possible for edges to change their configuration after things have been sliced up in booleans like in your case there.
3003.11 In reply to 3003.3
>To do that, set up the following as the command on a keyboard shortcut:
That's great!!
Marc
Show messages: All  1-6  7-11
