Text and Extrude Command
 1-5  6-23
2999.6 In reply to 2999.5
Hi, Michael.
It's my fault to describe inaccurately. They are surfaces, not curves.
I put the texts as surfaces and executed extrude command.
Anyway, I choose 4 fonts which "e" or "n" are extruded into the opposite direction.
The font names are put alongside, from the top, Arial, Century, MS Gothic (Japanese),
and AR Proportional Round Gothic M (Japanese). Please execute extrude command.
I'm really impressed that you make untiring effort to improve Moi.
I'll cooperate with you as possible.
2999.7 In reply to 2999.6
There is another problem related to font.
(1) Create text as solids (Height = 5, Thickness = 1, for example)
(2) Execute Fillet command (Radius = 0.1, Shape = Circular)
There are some letters which Fillet command takes no effect.
(See attached images, red letters are the ones. I tested two font,
Arial and Century.)
2999.8 In reply to 2999.7
Hi naoky, yes unfortunately that will not be unusual to have problems filleting text.
Text characters tend to have a lot of sharp angles, narrow regions, and tight bends in them - those are exactly the kinds of things that create difficulties in filleting. For a fillet to be successful it needs to have enough space for the fillet to fit, and things meeting at sharp angles tends to make difficulties with calculations and intersections of extended parts.
Filleting in general is a complex area that involves many functions such as surface offseting, extensions, and intersections so it is fairly easy for it to get messed up when there is difficulty with any one of those steps.
Probably several of those characters will fillet at a smaller radius value though - usually smaller radius values tends to avoid some problems. So for example I tried the Arial w character and was able to fillet it at a radius of 0.05 .
MoI's filleter is not generally strong enough to handle all font characters, if you need to fillet some more difficult things like that you may need to use one of the more "heavy duty" programs such as SolidWorks, Pro/E, etc...
I should be able to fix the original problem you reported earlier though, it turned out to be 2 bugs and I've nearly tracked them down.
2999.9 In reply to 2999.8
Hi, Michael.
Thank you for the description of difficulties about fillet.
The earlier problem is little, so don't overwork yourself.
2999.10 In reply to 2999.9
Sounds like you know what it is, but just some input here. If I shell it and then extract the back face, it then extrudes normally.
2999.11 In reply to 2999.6
Hi naoky, thanks very much for posting the 3DM file with the faces to extrude, that really helps me to track down a problem when I have can repeat it over here.
So it turned out that there were actually 2 different bugs here, and I've fixed them both for the next beta which I should be posting just a bit later today.
The first bug was that when creating Text as surfaces rather than solids, each face that was generated would not necessarily have a consistent normal direction, some could have a normal pointing opposite the others. That should be fixed up now so that they should all be consistent, and pointing in the same direction as the grid's "up" direction that you clicked on to place the text.
Then the second problem was that when extruding faces rather than curves, each face would extrude along its own normal direction, so they would go in different directions if they had different orientations. This was not quite exactly a bug, because having each face extrude along its own normal allows for some extrusions of different faces of a solid in one operation like this:
But what I did for this is to make a special case when you've got a bunch of faces that are all lined up on the same plane like the example in your file. In this case it will make a uniform direction between all of the extrusions now.
Please let me know if you still see any bad behavior with this for the next beta.
2999.12 In reply to 2999.10
Hi Burr,
Yup, the reason why that works is that when it got turned into a solid with shell, everything got a consistent normal direction at that time since it is possible to automatically determine the "outside" of a solid, which is not really well defined for just an open surface.
When you extract faces out of a solid, the extracted faces maintain the same directions as they were in the solid.
So those steps you did basically unified the normals to a consistent direction.
2999.13 In reply to 2999.12
hanks for the response there. I looked but couldnt find it. Didnt you have a command the would flip the normals?
2999.14 In reply to 2999.11
Thank you Michael, Frenchy and BurrMan.
I feel grateful for spending your time to my newbie problem.
I'm looking forward to the next beta, today!
2999.15 In reply to 2999.13
Hi Burr,
Yup, it's named Flip , but there isn't a button for it you need to set up a keyboard shortcut or type it in to use it.
2999.16 In reply to 2999.15
Go figure. The flip command is named Flip. Didnt think to look in the commands folder. Doh!
2999.17 In reply to 2999.14
The new beta is out now, you can get it from here:
http://moi3d.com/beta.htm
It will take me a bit to collect up all the release notes.
2999.18 In reply to 2999.17
Time limit was near the end point! :D
2999.19 In reply to 2999.18
Suddenly the option box has mucho roomo. Cant wait to see what I find! :)
Thanks Michael.
2999.20 In reply to 2999.19
Hi Burr,
Yeah it used to be fixed to a hard coded pixel size on startup. That could be too small if you were on a higher resolution display and had some larger font sizes for the UI text size.
Now it should hopefully adapt better to your font size.
2999.21 In reply to 2999.19
Hi Burr,
By the way, please let me know if it seems too big!
Hopefully now it should start out big enough to avoid needing a scroll bar for most systems though.
2999.22 In reply to 2999.21
It looks really nice. I just reviewed it on a 17, 19 and 30 inch monitor and didnt feel off in any way. I set a font size of 9 for my use and all looked well. The 17 produced "1 line" or so at the bottom that enabled the scroll bar, like the "lighting button" in the view tab. But it didnt seem odd. And I could resize it! Maybe a setting save that remembers the resized window state value would alliviate any issues for all scenarios. So you have a great all around setting now, but if I drag it a bit bigger on my small monitor to avoid scrolling, it returns to the default state. Can it write that value on exit?
2999.23 In reply to 2999.22
Hi Burr,
Yup, I think that should not be difficult. I probably should set it up so that any resizeable dialog (currently Options and Edit Styles are set up like that) gets its size saved in moi.ini automatically.
Show messages:  1-5  6-23
