Strange Fillet Behaviour
2992.1
Hi everybody,
new to MoI, I just tried to fillet some edges in beta 2.
Everything worked fine except with one that partially failed (-> screenshot).
Any ideas why ?
-Oliver.
Size: 123.9 KB, Downloaded: 107 times, Dimensions: 1280x994px
2992.2 In reply to 2992.1
Hi OLI,
has already been discussed
see here
http://moi3d.com/forum/index.php?webtag=MOI&msg=2872.22
-EDDI
2992.3 In reply to 2992.2
Thanks, Eddi, will go thru this.
Oliver
www.o5m6.de
2992.4 In reply to 2992.1
Hi Oliver,
> Any ideas why ?
It's because of the "seam edge" in the base surface shown with the arrows here:
That's probably the biggest problem with the fillets in MoI currently, they will not behave properly when they have to cross over a "seam edge" that is close to but not touching the original edges that are being filleted.
So to avoid running into that problem currently you would have wanted to rotate your base shape a little bit so that the seam edge was not so close to the piece being cut out.
I can probably patch that model up for you though, by copying and rotating in one of the pieces that did fillet ok and then trimming that into place, if you'd like to post the 3DM model file or send it to me at moi@moi3d.com, I can try to repair it for you.
2992.5 In reply to 2992.4
thank you for your fast response and the kind offer,
but I already found a workaround by slightly and unvisibly
reducing the fillet radius by a hundreth unit.
I have added what I finished so far of my Maxim MG.
BTW, I was amazed by the speed I got used to MoI
after fruitlessly testing 3DS and Blender..
Great piece of software, Michael, my deep respect !
Oliver
www.o5m6.de
Size: 120.9 KB, Downloaded: 75 times, Dimensions: 1280x1024px
