Change the color of all styles by a script
All  1  2-6
2987.2 In reply to 2987.1
Hi crydee, it is possible for scripts to access the color of styles.
So for example here is a script that will set styles to randomized colors:
script: /* Randomize style colors */ var styles = moi.geometryDatabase.getObjectStyles(); for ( var i = 0; i < styles.length; ++i ) { var style = styles.item(i); var red = Math.random() * 255; var green = Math.random() * 255; var blue = Math.random() * 255; style.color = (red << 16) | (green << 8) | blue; }
To run it, set up a keyboard shortcut and paste the above (as one long single line) in as the command part and then every time you hit that key styles should change to random colors.
But random colors does not guarantee that each one will be unique, it is possible for some of them to be similar, especially with dark colors.
But it may be useful and maybe you can just cycle through it several times until you get one that is pretty good and then manually alter a few of the similar ones.
A cool site for have some assorted colors from A photo ;)
http://www.degraeve.com/color-palette/
2987.4 In reply to 2987.2
thanks michael. your script is really nice. it works great. just another question. i need a shortcut for "adding a new style"and "edit style". can you help me again please?
thanks in advance.
crydee
2987.5 In reply to 2987.4
Hi crydee, yup it's possible to set those up.
To set up a shortcut for "Add new style", use this as the command:
script: /* Open Add new style dialog */ var gd = moi.geometryDatabase; gd.styleEditorOpened(); var dialog = moi.ui.createDialog( 'EditStyleDialog.htm?titleid=Add style dialog title&index=-1', '', moi.ui.mainWindow ); if ( dialog.window.doModal() != -1 ) { var styles = gd.getObjectStyles(); if ( styles.length > 0 ) moi.ui.propertiesPanel.editStyleIndex( styles.length - 1 ); } gd.styleEditorClosed();
To set up a shortcut for the "Edit styles" dialog, use this as the command:
script: /* Open Edit styles dialog */ var dialog = moi.ui.createDialog( 'EditStylesDialog.htm', 'resizeable,defaultWidth:380,defaultHeight:420', moi.ui.mainWindow ); dialog.window.doModal();
Hopefully that will get you wrangling your styles quickly... :)
2987.6 In reply to 2987.5
ah perfect. thats support. the bigger companies should take a close look to your response time. it's unique.
thumbs up.
have a nice weekend.
cheers crydee
Show messages: All  1  2-6
