Anyone having success exporting to Maxwell with N-Gons?
All  1-2  3-5
2974.3 In reply to 2974.2
Michael,
Thanks...I'm curious to hear if anyone has had a different experience. I'm trying to find a good solution to importing/exporting using MOI since it can read iges files. The n-gon export to c4d, on the otherhand, seems to work well and I'm trying to figure pros/cons for working with a mesh in c4d to then export to maxwell.
jvm
2974.4 In reply to 2974.3
n-gon support in an app is nothing else than handling triangulation within an n-gon shape without the user noticing it. C4D actually uses triangels to represent n-gons. You just do not see it. But you can make it visible.
Rainer
2974.5 In reply to 2974.4
Hi Rainer, yes that's true - however it is not particularly easy to make a good quality triangulation mechanism which handles complex outlines properly.
Unless some special care is taken during the triangulation process, it is easy to get things like triangles that "leak" to the outside of concave boundaries and things like that.
That's mostly why some programs do not handle n-gons well, they just do not have a robust enough triangulator.
Also until MoI came along it was not really very common to get a whole lot of complex n-gons in incoming data so in some programs it is just an overall less tested area.
Show messages: All  1-2  3-5
