WIP - Short Stirling
All  1-4  5-11
2966.5 In reply to 2966.4
Thanks for your example jpbweb, very instructive!
I will try this...
Marc
Very soft smooth result!
EDITED: 5 Oct 2009 by PILOU
2966.7 In reply to 2966.4
Hi JPBWE,
Nice to follow your project.
Just one note here :
Maybe you have to modify to get smooth connectivity ;)
thanks !
2966.8 In reply to 2966.7
Indeed.. The discrepancy was a very slight misalignment of the original two curves on which the cone is based. This meant that I had to start from scratch, which is just as well because the first version was not accurate according to photos I just found. This model of turret was only on the original batch of Stirling bombers, and as such not all that well documented.
I am not sure whether this new version is any more accurate, but at least it is smoother!
EDITED: 5 Oct 2009 by JPBWEB
Size: 78.7 KB, Downloaded: 31 times, Dimensions: 1024x768px
Size: 62.6 KB, Downloaded: 17 times, Dimensions: 1024x768px
2966.9 In reply to 2966.8
Maybe I should add that this turret is only 3.08 mm high.
I pride in pushing MoI (and Flamingo for rendering) to the maximum, but it is unlikely that a very slight curvature glitch could be rendered in the real world even with current leading edge 3d printing equipment. Even for a screen rendering of a completed aircraft, the bump maps alone would probably cover the glitch, even in a close up view.
Nonetheless, this shows that utmost care is required if going for top smoothness, but the tool can do it. I love MoI !
2966.10 In reply to 2966.1
Looks like a good start there Jean-Paul, keep it coming.
2966.11
Thanks for posting this - it is very educational.
Show messages: All  1-4  5-11
