WIP - WW1 Mark V Tank
All  1-2  3-5
2965.3 In reply to 2965.1
Hi Medi,
I'de like to see those boolean objects also. when you get time away from that "Great Model" to post them.
Nice work.
2965.4 In reply to 2965.1
Hi Malcolm,
Your tank has turned out great!
> If you are interested I can extract the objects from the
> scene and send them as a separate file to you.
Yes, if you could send just those pertinent objects to me at moi@moi3d.com I would appreciate it.
There is one particular area right now where the surface/surface intersector has difficulty, which is when 2 tubular type shapes come together and exactly touch each other at 2 sort of "crown" points. This may be related to that problem. Until that gets fixed in the geometry library you may need to do something like shrink one of the shapes slightly to change how they intersect with one another.
2965.5 In reply to 2965.4
Hi Michael.
I loaded up the tank model to extract the objects but I thought I would try one more time and, wouldn't you know, they united successfully! So I don't know why the problem originally occurred or what changed to make the union successful.
BTW I am also working on another model and encountered a situation where two objects wouldn't unite using boolean even though they were clearly intersecting. Tried a few times with no luck then looked at the properties of the objects and realised one was just a joined surface, even though it looked like a solid( I had used trim lines to divide up a cylinder). I must remember to check that all objects are solids before using boolean in future!!
Thanks for your interest.
Malcolm
Show messages: All  1-2  3-5
