Image backdrop -
All  1-3  4-6
2925.4 In reply to 2925.2
Hi Jamie - I'm not really sure where I would move the "Remove" button without it feeling really weird, it is kind of naturally paired with "Add".
But I think that a special undo that worked while you were in the Image command is feasible and should solve that problem.
2925.5 In reply to 2925.3
>> Right now it may be helpful to draw a rectangle to snap on to before running the command.
That's exactly the point, I was trying to place 5 images to create a 'classic' car blueprint, without any geometry behind to 'drive' the placement.
For sure, by creating first the car bouding box, image placement is much more easier.
Probably I just have to be used to that workflow ;)
2925.6 In reply to 2925.5
Hi PaQ, I've seen a few different image layouts for cars, it still may help if you could show me a sketch (even just a rough one) of the particular layout that you're trying to get.
Also I don't know if it applies to your situation but here is a previous illustration on how to align one image to match up along side an existing one:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2501.15
Show messages: All  1-3  4-6
