Curve text
 1-7  8-27  28-47  48
2920.8 In reply to 2920.7
if there was the video would be very helpful :)
2920.9 In reply to 2920.8
Here's a sample. It can be very precise. (Screen recorder makes it a bit more jumpy on my end)
Remember this is the V2 beta, so V1 wont do this.
Good luck.
2920.10 In reply to 2920.9
Great video tutorial BurrMan!
Michael Tuttle a.k.a. mictu
http://www.coroflot.com/fish317537
2920.11 In reply to 2920.10
Very kind Burrman !
Thank :D
2920.12 In reply to 2920.9
Hi Burrman,
Just as an aside... what did you do to color your MoI icons? Are you using a custom UI?
Jesse
2920.13 In reply to 2920.12
Hi Jesse,
I actually got them from Grnedel here in the forum. I think he just took the png files into photoshop or something and re-colored them. If you want "them" I could dig them up for you, or you could just hue adjust your own Icons however you like.
MoI's UI is fully customizable. Either by structure with html files, or by the images that are what you are seeing there with the buttons and such.
Before the beta's started rolling out regularly, There were some guy's working on "Custom UI" skins (User=ASH) that you could apply to MoI that were very cool. I think when the next release rolls out, you may see a couple of these come out again...
2920.14 In reply to 2920.13
Hi Burr...
I am not familiar with Photoshop.
If I can, maybe I will convert all the MoI grey icon to colorize icon.
Maybe someone that expert in Photoshop can do this for us... :) ?
It will very good to have MoI with colorize icon.
Make the UI more fresh ;).
I forgot the link from Grendel.
Burr, have you the link or would you like to upload your color icons here ?
Many Thanks !!!
2920.15 In reply to 2920.14
Hi Anis,
Here they are, courtesy of Grendel!
Put them into the UI\Icons folder. You may want to backup the original Icons in case you dont like it.
Again, once the release is out, there will probably be some customization that others do offered up in the forum.
2920.16 In reply to 2920.14
Well seems had it wrong! The kudos go to lyes!!!
Same Icons you received before Anis. Here's the link:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2557.36&highlight=yes
2920.17 In reply to 2920.15
Hi Burr,
I hope to have colorize icon for all MoI UI.
Wish user can contribute for this project.
Looks like Michael busy with scripting :)
About Photoshop you have a similar free one online SUMO PAiNT ;)
http://www.sumopaint.com/home/
2920.19 In reply to 2920.18
Hi Pilou...
Thanks for the link.
Maybe we can also use software like Inskape or Gimp.
The problem is not on the appication that I have to use, but I dont know on how to use Photoshop to convert from GREY Icon to COLOR Icon.
It will be vey good if Iyes can give us tutorial on how to convert from Grey to Color Icon.
Then later I can convert another Icon by my self or maybe another MoI user can help :)
Thanks !
2920.20 In reply to 2920.19
< It will be vey good if Iyes can give us tutorial on how to convert from Grey to Color Icon.
In Sumo Paint that is Menu Adjustments / Color Balance ;)
EDITED: 30 Sep 2009 by PILOU
2920.21 In reply to 2920.20
The thing to rememeber is it's not an "ICON" but a simple image in PNG format. Most photo software applications have an adjustment operation that will do something basic like this. You will just need the abilty to save it out as a PNG again.
Look for "color Adjustment" or "HUE" or something like that. Even the simple software that comes with todays digital cameras usually have the abilty to "Adjust" the image.
2920.22 In reply to 2920.21
@ Pilou & Burr...
Thanks for your guide on how to edit MoI png to be more colorful.
I will create a new thread for collection of MoI Color UI.
Thanks ! :)
Sumo Paint has the PNG and then also the transparency for it ;)
EDITED: 1 Oct 2009 by PILOU
2920.24 In reply to 2920.23
Hi Guys...
A little problem when change the color of Offset.
When I pick the button it will go like this :
Normally in other default button is below :
Any clue... ?
Thanks ! :)
EDIT : Michael...., maybe you can split discussion that related to modify MoI Icon.
2920.25 In reply to 2920.24
Just testing modify rect section, but got this :
EDITED: 19 Jun 2010 by ANIS
2920.26 In reply to 2920.25
Hi Anis, WHat you need to look for when you re-save your image is to set the "
Transparency color". WHen you do the save with PNG, there should be an option to set this, then use a color picker to set the background as transparent.
FYI.
2920.27 In reply to 2920.24
Hi Anis,
It looks like it's got a solid white color for the background rather than a transparent background.
Like Burr mentions, the background needs to be maintained as transparent for it to look like the regular icons.
Show messages:  1-7  8-27  28-47  48
