Wireframe mental block
All  1-11  12-17
2908.12 In reply to 2908.7
Hi Jean-Paul,
> What I like about the NURBS approach is the capacity to generate
> in a split second a huge and complex model made out of a few simple
> lines, as this is the way engineers created the real world planes and
> ships in the first place.
Yup, that's where NURBS is strong - that you can create a lot of shapes quickly by drawing just a few input curves, and using construction tools that use the curves.
With sub-d modeling you do have to kind of manage a lot of points floating around in 3D which is kind of a specialized skill. It's more spatially complex to work a big mass of 3D points than it is to work with 2D curves.
But the NURBS methods are best applied to shapes that are very well defined by their profile curves - when things are kind of melting/blending in many directions the profile of the shape is not really a primary definition of the shape anymore and that makes things more difficult.
> A viable strategy for the tough cases might be to get as far as I
> can with MoI and then switch to Modo for the finishing touches.
I think this is a good general strategy.
> Hence the emphasis on continuity. This being said, it appears that
> I may have gone a bit overboard about that because the limitations
> of the 3D-printing process (although already black magic to my
> bewildered eyes) make it so that a slightly noticeable continuity flaw
> on my computer screen might be entirely absent in the real world output.
Yes if your final output is going to be at a fairly small physical scale it would probably serve you well to kind of turn down the level of concern for getting perfect continuity.
If you don't worry about it as much, that will tend to free you up some more to build things in a kind of "skin the wireframe" type method like you were wanting to use here.
> Planes and ships, especially military ones, tend to be rather
> complex objects, but they are hard surface things.
Along with automobiles the exterior of those kinds of vehicles are kind of in a gray area where the shapes are becoming more in "organic" territory and less defined or driven by 2D plan curves alone.
> like for the B-29 front wheel, a component way more suited to
> MoI's capability, I guess.
Yes, definitely - that one is a perfect candidate for a profile curve driven approach.
2908.13 In reply to 2908.10
Hi Jean-Paul, I was messing around with your wireframe a bit more and I thought I'd share one note that may be generally useful to you when trying to use this kind of "make skin over wireframe" type method.
It's regarding this area where you may have a 3-sided region you want to fill in:
You've probably seen before where doing a Network on those 3 sided areas separately will make some undesirably bulging/puckering like this:
That happens because the curve pieces are of different lengths, and the upright profile can kind of sway back and forth as it gets merged with the other pieces, making for a kind of twist in shape.
But you can use Sweep with a special option enabled as an alternative which will work better in this situation, if you've got a simple planar profile piece like this:
What you do is select that planar profile, then run Construct / Sweep, and activate the "Maintain tangent" option:
That will cause the sweep to get generated by keeping that profile in the same plane and marching it down the rails and getting intersections with the rails and the plane, if you look at the control points of it you can see that regular planarity to them:
(EDIT: you would actually have seen it even more clearly if I had taken a top view snapshot, here to see that the surface control points are all arranged on parallel planes).
That's different than a regular sweep where the profiles kind of "slide" along the rails and can get that kind of twisting introduced if they are of different lengths.
Sweeps that are done with the "maintain tangent" option will more rigidly preserve the shape of the initial profile, which gets this kind of a result even when doing them as 4 separate sweeps:
2908.14 In reply to 2908.13
Michael,
Thats nice! One thing I was doing the other day when using network, was utilzing "RebuildCurve" to make all the curves have the same amount of points. I thought it was making a difference in the result! ???
Was I correct and does this relate to the different length thing you just pointed out?
2908.15 In reply to 2908.14
Hi Burr, well it is hard to say anything for sure without seeing the particular curves...
But Network actually does a process like RebuildCurve internally. However, instead of doing it to a fixed number of points, it continues to add points until the rebuilt curve achieves a maximum distance tolerance away from the original input curves.
So if you smoothed out the curve or made it less wiggly or something by doing a RebuildCurve on it, that could possibly make the difference that you saw.
Well, rebuilding several curves doesn't necessarily make them the same lengths even if they have the same number of points in them.
Maybe focusing on the length was not the right way to describe it - basically when you do a Network there is a kind of averaging process where the result is a combination of all the input curves in a equal way.
But in the kind of situation that I was showing previously, it is not really good for the input curves to be treated totally equally, it's better in that case for that upright profile curve to kind of have more emphasis placed on it kind of making it more of the primary shaping agent rather than a more equal blending between all the curves.
2908.16
Michael,
Thanks for your quality input. This thread has made me learn a few more tricks. I never quite understood before what the “Maintain Tangent” option did. I had tried tu use it but I saw no noticeable difference. Now I know (at least I think I know…)
On a related topic, what about this cage editing tool that is part of Rhino 4.0 ? Is this a kind of thing that would make smooth deformations easier for NURBS objects? Is it on the wish list for MoI ?
2908.17 In reply to 2908.16
Hi Jean-Paul,
Yeah it won't have an effect in just any sweep, the conditions need to be right for it to be able to be used, like the profile needs to be planar and if there is more than one profile they have to all share a same tangent direction where they touch the rails.
Also if you have exactly symmetrical rails then it would not really do anything because in that case the profile also slides along each rail in equal distances with each step.
It's when the 2 rails are different in shape and length that the profile will tend to twist as it is moved by sliding along the rails since the "slide distance" on each side is different in that case, except not with "Maintain tangent".
Maybe it should have been called "parallel planes" instead.
Yes, it would help to kind of squish objects around. It is on the wish list for MoI but I'm not sure when it will happen. It is difficult to make it work on a solid that has joined edges and still keep the edges stay connected in the deformed result, especially when the joined edges are trim edges that are located somewhere internal to the underlying surface rather than a natural surface edge.
Show messages: All  1-11  12-17
