The other thing that you may try is to make a second network that is smaller than the first one and use that as the inside surface rather than trying to do it with shell.
That would be more like building each surface of the final thing individually, sometimes that can be easiest with a shape that has some complex curvy bits that cause problems with offset calculations.
