Plane Problem
All  1-11  12-14
2884.12 In reply to 2884.11
Hi NightCabbage, yup I'm definitely interested in them, but they aren't really a "natural fit" with the NURBS structure and will require quite a lot of work to make them happen in a way that does not make broken or invalid objects too easily.
So that means I don't really know when it will happen, possibly not for a fair amount of time.
2884.13
I usually use the command 'ShrinkTrimmedSurface' which shrinks the underlying surface to the boundaries of the new shape.
You can find the explanation here....... http://moi3d.com/wiki/Hidden_Secrets
12th Secret from the top.
2884.14 In reply to 2884.13
I also struggled a bit with NURBS at the start. I had only just started to get the hang of polygons :-)
I try to think of NURBS more as a block that I am going to cut bits away from to make my final shape. I use other shapes to cut the block into whatever you want. I use booleans and extrudes more than planes.
For your building I would have started with a block then used another block to cut out the corner. This would have left me with a solid model.
Tony
(aka HamSoles)
Show messages: All  1-11  12-14
