3DS problems
All  1-4  5-7
288.5 In reply to 288.3
Is there possibly some kind of clipping plane set up on those views which is causing it not to draw there?
I took a look in the .3ds file structure, and I can't really see anything that should cause this to happen within the file itself, and that .3ds file seems to load normally into Rhino and Cinema4D...
Maybe I will be able to try and download the demo version of 3ds max tomorrow to test it some more.
288.6 In reply to 288.4
288.4 In reply to 288.3
I just pulled down the files and tested it myself, no problems here. (3ds max 9 32 bit)
What happens if you scale up the model by 2000% and then zoom extent all again? Maybe it's a near-camera clipping thing...
I did that, no change. However, what I just found out is that pressing middle mouse button and drag (that is the pan command) makes the objects appear. After that, I changed the views from Wireframe to Smooth&Highlights and now the objects are visible.
Well, I still think there is a problem, I will do some more tests
288.7
Can anyone confirm the problems with 3ds from MoI? I don't see my 3ds import to MAX8 in wireframe mode.
Show messages: All  1-4  5-7
