3DS problems
All  1  2-7
288.2 In reply to 288.1
Hi JTB - well this sounds like an odd problem.
I don't have Max over here, so it will be a bit tricky for me to track down what is happening.
If you create a box inside of Max and export it to .3ds, does that work correctly when you read it back in?
If it does, could you please post here the .3ds file exported from Max which does work, and also the .3ds file from Moi that doesn't work? I will then try to compare them and try to see what Max doesn't like about the MoI file.
Maybe something with your video card is behaving oddly, it might be a good idea to reboot your machine and try it again.
288.3 In reply to 288.2
Michael, I send you a ZIP containing the 3dm file, the 3ds from Moi, a 3ds from Max, and 3 screenshots from Max.
EDITED: 31 Jan 2007 by JTB
288.4 In reply to 288.3
I just pulled down the files and tested it myself, no problems here. (3ds max 9 32 bit)
What happens if you scale up the model by 2000% and then zoom extent all again? Maybe it's a near-camera clipping thing...
288.5 In reply to 288.3
Is there possibly some kind of clipping plane set up on those views which is causing it not to draw there?
I took a look in the .3ds file structure, and I can't really see anything that should cause this to happen within the file itself, and that .3ds file seems to load normally into Rhino and Cinema4D...
Maybe I will be able to try and download the demo version of 3ds max tomorrow to test it some more.
288.6 In reply to 288.4
I did that, no change. However, what I just found out is that pressing middle mouse button and drag (that is the pan command) makes the objects appear. After that, I changed the views from Wireframe to Smooth&Highlights and now the objects are visible.
Well, I still think there is a problem, I will do some more tests
288.7
Can anyone confirm the problems with 3ds from MoI? I don't see my 3ds import to MAX8 in wireframe mode.
Show messages: All  1  2-7
