Trim Idea
All  1-3  4-8
2850.4 In reply to 2850.3
Hi Marc,
> I also though a couple of times about a key that could
> trigger 'add trim points' while in trim command.
> But then again it might not be possible to do so, but it
> would be nice.
Yes, you can set up a keyboard shortcut that would be the same as pushing "Add trim points" - to do that put the following as the command for the shortcut:
script:moi.ui.fireUIEvent( 'addtrimpoints' );
> On another note I've finished the sea kayak project
> yesterday... 384 hours!!
> Lots of cedar trim!
Congratulations! That sounds very cool. Do you have any pictures you can post to show it off?
2850.5 In reply to 2850.4
Thanks Michael, the shortcut works great!
Here's a picture of the kayak...
Size: 187.4 KB, Downloaded: 128 times, Dimensions: 1024x768px
2850.6 In reply to 2850.5
Wow! So beautiful!
/Lars
2850.7 In reply to 2850.5
Hi Marc,
Wow, it is gorgeous!
2850.8
Thanks!!
It handles much better than those I used to rent!
The wood has fiberglass inside and outside, a kind of sandwich.
Glassing and epoxy was the hardest part for me .
Marc
Show messages: All  1-3  4-8
