are there any full length car tutorials?
All  1-4  5
2842.5 In reply to 2842.4
Hi angeliclight,
> is it a good process to use - the using of photographs for each
> axis - for objects you want to model from real life, too?
It's more common to use blueprints or technical plans which are not exactly the same as photographs.
For an example see this tutorial from one of those previous links:
http://www.suurland.com/tutorials_newbeetle.php
There is a different kind of software and modeling process called photogrammetry which involves a process of analyzing multiple photographs from different angles and identifying common points in each one to produce a model.
That's a much different kind of modeling process than MoI, if you are interested in producing models from photographs you might want to check that out, there is a variety of software out there for that, one example is PhotoModeler http://www.photomodeler.com .
Show messages: All  1-4  5
