are there any full length car tutorials?
All  1  2-5
2842.2 In reply to 2842.1
Hi robotninja, cars tend to be a pretty high level of difficulty and will likely take a fair amount of time invested to get going with them. But here are some links that may be useful:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2687.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=2546.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=1267.16
http://moi3d.com/forum/index.php?webtag=MOI&msg=898.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=1749.1
http://www.suurland.com/
http://www.carbodydesign.com/ (try the 3D Tutorials section, in the Rhino section).
2842.3 In reply to 2842.2
What about more general tutorials about modeling any sort of object just from photographs?
Would the process be the same if you were doing a building (from photos) or something smaller like from photos of an oven?
You know...someone needs to write a "Modeling with MOI" ebook. The amount of money they'd make would be staggering considering the number of people that are fairly new to modeling when they come to MOI.
I know there's lots of advanced 3D folks that do well with MOI, but there seems to be a large user base (like me), also, that comes from more expertise with 2D apps.
I'd buy a MOI-specific ebook (or whole series) on how to model. Easy.
2842.4 In reply to 2842.3
Continuing from the last...is it a good process to use - the using of photographs for each axis - for objects you want to model from real life, too?
Sorry if this doesn't make sense - I'm new...
2842.5 In reply to 2842.4
Hi angeliclight,
It's more common to use blueprints or technical plans which are not exactly the same as photographs.
For an example see this tutorial from one of those previous links:
http://www.suurland.com/tutorials_newbeetle.php
There is a different kind of software and modeling process called photogrammetry which involves a process of analyzing multiple photographs from different angles and identifying common points in each one to produce a model.
That's a much different kind of modeling process than MoI, if you are interested in producing models from photographs you might want to check that out, there is a variety of software out there for that, one example is PhotoModeler http://www.photomodeler.com .
Show messages: All  1  2-5
