Problem with Windows 7
2835.1
have a little problem with MoI and Windows 7.
If you look at the attachment, you will see that there is no button for "OK" or "CANCLE".
Is there another way to confirm the lincense key?
Greetz Dennis
Size: 38.5 KB, Downloaded: 57 times, Dimensions: 516x318px
2835.2 In reply to 2835.1
I think that this is due to version 1.0 and has been patched.
What version of MOI are you trying to install?
2835.3
1.0, but at my other PC (VISTA is running on it) it works fine!
2835.4 In reply to 2835.1
Hi Dennis,
I think this is related to a bug in IE 8 in Windows 7 RC , as Phil mentions there is a patch available for MoI V1 to fix this.
You can find a related post here http://moi3d.com/forum/index.php?webtag=MOI&msg=2572.1
Patch download here http://moi3d.com/download.htm Version 1.0 to 1.1 update
If symptoms persist see you local MG ;)
2835.5 In reply to 2835.4
Yup, Danny has it correct above, thanks Danny!
Yes it's due to IE8 - your other vista machine is working fine probably because it has IE7 installed on it and not IE8.
You need to install that version 1.1 update from the link that Danny posted above, to get MoI v1 to work on a system where IE8 has been installed.
2835.6
Thank you all guys! The patch fixed the problem!
