Simplifying Splines
All  1-5  6-7
2818.6 In reply to 2818.5
That's OK Michael, I was more curious than actually needing this function now, V3 or 4 is fine.
2818.7
By the way there is a way to reduce machining time of complex 3D surface even though you use "dumb" CAM software and/or old CNC controller. You can simplify a true G-code using MetaCut Finish (http://www.nwdesigns.com/Products/MCFinishNutshell.htm) by fitting arcs, lines or curves (nurbs) to the point-to-point toolpath. -Petr
Show messages: All  1-5  6-7
