getting splines out of moi.
All  1-5  6-7
2817.6 In reply to 2817.5
Hi okapi, thanks for posting the files.
It is like I had guessed - the one that works has the object stored as a POLYLINE entity, and the one that does not work (from the conversion utility) has it stored as a SPLINE entity.
So it looks like Modo and C4D only support reading Polyline data (which are a sequence of line segments) from DXF files and not actual smooth curves.
Right now there is not any way set up for MoI to write that particular kind of data to a DXF file, so you will need to use Rhino currently to do that conversion.
2817.7
Thanks for looking into Michael.
Show messages: All  1-5  6-7
