getting splines out of moi.
All  1-3  4-7
2817.4 In reply to 2817.3
Hi okapi, I'm not really sure, but possibly those other programs will only read some certain kinds of entities out of a DXF files and not SPLINE type entities.
Maybe Rhino writes out that rectangle as a POLYLINE type entity in the DXF file and that matches up with what those programs are looking for.
I could probably figure out some more details if you could post 2 example DXF files - one with a rectangle in it that did not work going into those other programs, and one with the rectangle DXF file that does work.
2817.5
here are three files.
This is a very simple setup.
The lines are imported into both modo and cinema4d when the 3dm file is exported via Rhino.
2817.6 In reply to 2817.5
Hi okapi, thanks for posting the files.
It is like I had guessed - the one that works has the object stored as a POLYLINE entity, and the one that does not work (from the conversion utility) has it stored as a SPLINE entity.
So it looks like Modo and C4D only support reading Polyline data (which are a sequence of line segments) from DXF files and not actual smooth curves.
Right now there is not any way set up for MoI to write that particular kind of data to a DXF file, so you will need to use Rhino currently to do that conversion.
2817.7
Thanks for looking into Michael.
Show messages: All  1-3  4-7
