New lighting model WIP
 1-14  …  55-74  75-94  95-114  115-134  135-138
2801.95
This looks great Michael, I was content with just your light flip script but you really kicked it up a notch. As far as the custom lighting goes would be be able to save a custom light set up or two possibly?
2801.96 In reply to 2801.95
Hi Grendel,
Thanks! Actually that old flip light direction script will still work, but yes the idea is that it should not be necessary anymore since there are now multiple fill lights that help to illuminate the dark sides.
There is kind of a trade-off though with more light also meaning less contrast, so that's why I wanted to set up a variety of choices and adjustments.
It's possible to set up a shortcut key script that will do anything that you see there in the UI, so you could have a couple of different keys that would set things to particular values.
Also another idea is that this UI I showed above would be for setting your normal default lighting, and then there will maybe be a different thing under the View palette that will let you flip between some different view modes that would temporarily override both lighting and things like surface colors too.
2801.97 In reply to 2801.96
Remember Grendel, Anything that you can put in a shortcut command, you can save in a js file and place a "scripts" folder in the root of MoI, then just type that name in the command area to get it. So no need to fill up keys, just call by your personal name like, "Garden", "Automotive or whatever!
FYI
2801.98 In reply to 2801.97
So any way to capture the current custom lighting to the clipboard or something?
2801.99 In reply to 2801.98
Hi Burr,
Hi Burr, well the custom light levels are controlled by just 2 numbers, so it shouldn't be hard to just write them down.
2801.100 In reply to 2801.99
OIC. Didnt see those in the video. Will those numbers be the same correlation in the script? When you give one example script after its done, then we could just fill in the different numbers to create the different setups as scripts.
2801.101 In reply to 2801.100
Hi Burr, yup those numbers will be the same ones used by the script.
One of the nice things about how MoI's UI is set up is that the UI always talks to the core MoI code through the script interface. So that means that any numbers or things you see controlled by UI can also be controlled by a custom script as well.
Yup, that should work pretty good.
All right, I've got some good progress on specular highlights also now.
Here's an example:
Here's one with the metallic option also enabled:
When you enable Specular highlights, 2 additional sliders appear in the UI that let you adjust the Brightness and "Focus size" of the highlights.
Here I've taken the above one and loosened the focus and dulled the brightness some, it gives more of a sheen to an object rather than a hard looking small spot:
2801.103
Hi Michael:
Could be the new lighting modes a problem with an older graphic cards?
2801.104 In reply to 2801.102
Looking good there Michael, looks like your bordering the rendering side of things :)
BTW will you be looking at an option to have black edges also or is that out of the question ?
2801.105 In reply to 2801.103
Hi David,
Actually one of the cool things about this display stuff is that it is compatible with old cards as well, it should work all the way back to the original Radeon or GeForce1 cards.
All the screenshots that I posted are from a Radeon 9600 Pro card which is 6 years old.
I've tested it here on a Radeon 7500 and a Geforce2, which are very old - and actually you should upgrade to something newer if you have one of those because you can get something several generations newer and much faster for only about $30.
I think you would need to go back to about a 10 year old card for it to not work. I'm not sure yet about other than ATI or nVidia cards though, it is possible that some other systems like Intel integrated graphics may not have the support needed until somewhat more recently than that. If a card does not support what is needed, it will fall back to the old style basic lighting and all those new settings will not do anything in that case.
But it is likely that if you have a good enough graphics card to run MoI well now, that it should work fine for these new display options as well.
2801.106 In reply to 2801.104
Hi Danny,
I'm going to be looking into some options for a "display override" type mechanism, I'll probably be able to fit an option for overriding the color of edges into that.
I'm not quite sure exactly how it will work quite yet but probably you'll be able to edit a text file that has a list of different display modes for things like "Matte White", "Shiny Blue", "Metallic Red", etc... so that there can be a control that will let you flip between these different display modes. The way that will generally work is that each mode will list some properties that it overrides from the normal default view, so something like an edge color property could fit into that same scheme pretty easily I think.
2801.107 In reply to 2801.106
This all looks wonderful!
A matte white ("mud render"-like) mode, and something where you get black lines and, better still, black lines with depth-cueing, a la sketchup, would be really nice -- while it'll obviously never be a substitute for renders for anything that has to go in front of a client for real, getting fast, decent looking screenshots is still really handy.
/Ella
2801.108
I'm definitely THIRSTY for this now!
One question, Michael - how does the lighting look if you're inside the model??
A lot of my models - buildings, docking bays, etc., require me to be inside the model for some bits - will it be like it is now, still lit inside or out?
-Will
2801.109 In reply to 2801.108
Hi Will,
Yeah, it's the same as currently - basically it works like that so that objects that are open surfaces will look proper rather than having an arbitrary half of the surface all darkened.
2801.110 In reply to 2801.109
Looks fantastic, Michael. I'm digging the soft specular highlights.
I just want to add that I second Danny's desire to see black surface edges. I thought it would have been a checkbox option or something, but making it available in a config file seems accessible enough. Wouldn't it be more functional to have surface curves black and free standing curves colored according to their style (especially if you add the option to display/alter isoline densities in the future)? Blah, this is probably a discussion that was held earlier on in the forums. I'll look for it. Anyway, great job!
EDITED: 30 Jul 2009 by VODKAMARTINI
2801.111 In reply to 2801.110
Hi vodkamartini,
re: Black edges - yes there was some previous discussion of that earlier here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2801.28
But note that you can get black edges right now if you want, just select all edges (quick way is to go to the scene browser / Types and click on the text part for the "Edges" entry), and assign them to a style that has color=black.
In MoI edges can be assigned their own styles and names, and be hidden and/or locked same as a regular object.
You're probably not used to that since Rhino does not have the ability to do that.
The same thing applies to faces as well, for example you can assign different styles to face sub-selections without needing to break it apart into individual surfaces.
2801.112 In reply to 2801.107
Hi Ella - I've added another option called "Fixed light positions" which when enabled makes the lights stay fixed in place instead of moving along with the camera as they normally do.
I think that combined with the "Hemispheric" lighting option should give you a mud-like matte style.
Depth-cueing will have to wait for some future version.
2801.113 In reply to 2801.112
Oh, wonderful! I was assuming that that'd be a v3 thing. Great! And yeah, I understand depth cueing being a completely different issue, being, you know, not a lighting thing at all. :-) Thanks.
/Ella
2801.114 In reply to 2801.113
Hi Ella, here is what that Hemispheric style + "Fixed light positions" looks like:
Show messages:  1-14  …  35-54  55-74  75-94  95-114  115-134  135-138
