Nice bevel or radius on surface of Chinese characters
 1-2  3-22  23-42  43-55
2799.43 In reply to 2799.42
Yes Pilou, that is IMHO the best sulution.
My English is too bad, in order to explain it better.
We use .*eps (Rails) whenever we can, it significantly shortens the creation time.
EDITED: 29 Jul 2009 by RALF-S
2799.44 In reply to 2799.42
Pilou - Thanks for demonstrating the Rail Revolve.
I don't know if Rail Revolve is intended for this application, but in some ways it works better than fillet because it seems to work in tight V shape corners.
However I tried it on a similar shape and also got a result where the profile curve cuts into the shape in some areas (see red arrow) in your example.
Do you know how to get the profile to work in this situation?
Ed
2799.45 In reply to 2799.44
It's the result of the placement of the first point of the axis!
As it's not a symmetric figure sides can be curvated!
But as you can rotate the volume this can be hidden for 2D illustration ;)
Or find another place or angle for the axis !
Or rotate the profil!
It would be nice to have a function called Bevel that would take a plane and extrude while applying a radius profile. You can do the same using extrude plus fillet, except fillet doesn't work well in tight V shape areas because the profile wants to fold back on itself. Is variable radius fillet the answer here?
I'm just thinking out loud here, but I often want to take a shape like the Kanji Characters and turn them into solids with nice rounded edges, regardless of the shape. Much like cutting the shape out of flat aluminum stock and letting it run in the tumbler for a couple of days. The analogy is that in a tumbler, the edges that stick out will get rounded more than the tight recesses that are not as exposed to the tumbling media.
Ed
2799.47 In reply to 2799.46
Hi Ed, I do want to add a function called "Tapered extrude" which I think is what you are talking about. Originally I had hoped to include this for v2 but it does not look like that will happen currently, so probably in v3.
You can actually get the same result though currently by using Offset on the curve, then moving the offset in the Z direction and doing a Loft. Check out this previous post for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=941.5
2799.48 In reply to 2799.46
Ed,
Blend will make a nice edge around this charater, but the thickness is limited to where it will fold in on itself. SO the original thickness couldnt be acheived using this.
Make a duplicate character and move it up a bit in Z, then planar both and delete the curves. Now select edges of the 2 surfaces and blend. You'll have to drop the value down till it fits nicley.
Pilou's solution will work also, you'll just have to toolpath "both sides" to get the opposing direction "fillets", but it could still make a nice cut. Good catch Pilou!
2799.49
Thanks Pilou for the great example of rail revolve.
Michael, Thanks for the "Taper Extrude" link.
Joe
2799.50
Hello All,
Just wanted to pass on a finished carve image of my Chinese character.
Until I get up to speed on Moi and ZBrush I ended up using another package to create the bevel on the character.
I also wanted to thank everyone for all of the great assistance.
Joe
Size: 43.9 KB, Downloaded: 92 times, Dimensions: 426x640px
2799.51 In reply to 2799.50
Excellent work Joe!
Nice work Joe.
I take it this was one solid piece? How long did it take to cut?
Ed
2799.53
Thanks Burr,
Ed, Yes, Carved from 3/4" purple heart wood. It took 45 minutes to carve. The character is relief cut at .25 inch.
Joe
Message 2799.54 deleted 5 Aug 2009 by BURRMAN
2799.55
Thanks Burr,
That is definitely a technique I can use for some future projects I have in mind.
Joe
Show messages:  1-2  3-22  23-42  43-55
