Hi Indy,
> Are there any hints on how to easily find the missing faces in general?
I just found yours by just doing a quick inspection of your shape...
But it is possible to set up a keyboard shortcut to highlight naked (unattached) edges, which can help to show you where the disconnected holes and empty spaces are in a model.
To do that, go to Options / Shortcut keys and add in a new entry, and for the command, paste in the following (it is all one long line):
script:var gd = moi.geometryDatabase; gd.deselectAll(); var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );
Then when you hit that key, the edges that are not attached to anything should highlight.> And before I forget... any indications about when V2 will be out? ;-)
No firm date set  yet, but hopefully not a whole lot longer.
