Lofting Problem
All  1-15  16-19
2791.16 In reply to 2791.15
I think the segmented seam curves will become less of a factor as MoI matures.
2791.17 In reply to 2791.14
Hi Danny, just a quick note on continuity - when you have a curve that is a "single segment" (formed with only one single spline instead of multiple splines touching end to end), if it is the most common cubic curve than that does give you an internal G2 continuity throughout the whole spline unless there are special things like fully multiple knots or stacked control points.
That's for NURBS curves though - a "bezier curve" as often made by 2D illustration software is not as good for G2 continuity because it basically has fully multiple knots for every curve span.
It's pretty frequent for curvature combs to be somewhat misused and over obsessed with though - when the comb itself has cusp points in it, that is actually G2 continuity, that's when the curvature is equal at a juncture point.
When the comb is completely smooth throughout, that actually means G3 continuity, where the rate of change of the curvature is continuous, not just the curvature itself being continuous.
There is not really as much of a physically noticeable difference between G2 and G3 continuity like there is between G1 and G2 with reflection lines.
The other thing is that it can often be better to be more concerned with "fairness" rather than the actual technical continuity. Pieces can be technically continuous but still have poor curvature distribution. Continuity is about how things match up at a certain point but not really about how they are distributed which tends to be actually more important in shaping.
2791.18 In reply to 2791.15
Hi Jean-Paul,
If you like no seam lines in your models, then yes, I agree in what your doing, but there would be some situations where you can't avoid them, I think the extra work has minimal effect for the final outcome, like the model with the seams is quite acceptable, you can still apply a fillet around the hole the only difference is you have to pick 3 edge segments, but it still fillets.
All I'm trying to say is one method is as good as the other, I don't think in saying that the model with seams, is less than desirable is a correct statement.
EDITED: 21 Jul 2009 by DANTAS
2791.19 In reply to 2791.17
I agree with this, I don't really use comb analysis much myself.
I was just trying to point out to Jean-Paul that there was nothing wrong with the curve with the G2 blend that produced seams in the model.
I was trained with all these rules in producing 'technically correct' curves and felt then that it took the gloss off 3d modeling a bit.
There's a definition I like for A-Class surfaces that I came across.
"An A-Class surface is a surface that is smooth and appealing to the eye"
So I figured no matter how the surface was built, as long as it looked smooth and flowing and the reflections were good, it didn't really matter what degree or how many segments and what the comb looked like for the underlying spline.
Show messages: All  1-15  16-19
